Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
553 Questions View all
need help with stator do I need a voltage regulator or Diode
i got a riding mower with a Kohler CV15S i got a voltage regulator and hooked it up but when connecting the middle wire to the battery it sparked so i got to thinking maybe the stator shorted out so i got the flywheel off and i can see 2 copper wires are together and grounded with a screw its made that way so should i use a diode for this kind of stator? and take the voltage regulator back off ?
Add a comment
1 Answer
Most Helpful Answer
Anytime that you have a battery system connecting to the stator like an alternator, you would need a diode, this prevents the reversing flow of the electrons to the other circuits to cause the damage like shorting out. I would also see if you can find a repair manual on your engine, there would be more technical information in it.
Score 1
Add a comment
Add your answer
Tim Prichard will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 41
All Time: 1,376
