Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Why isn't my phone turning back on?
My IPhone 5s was working and then it wouldn't work anymore. i had replaced the battery because this has happened before. But I thought it was fixed, then it happens again. Some suggestions have been that it could be the lightning connector but im not sure what it could be. Back when it would go black and would be unresponsive I would take it apart and disconnect the battery and connect it back, and then it would work. But then it just wouldn't work. I tried disconnected it again, and now nothing. I have important things on this phone and need help. Any suggestions on what to replace now?
Add a comment
1 Answer
try a known working battery, the lightning port is the charging port which you may try a new one. If both do not repair the problem then the Tristar IC AKA U2 IC may be bad which can also be repaired to save important data. This is a microsoldering issue.
Add a comment
Add your answer
Ryan Smith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 27
