Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Phone won't turn on after charging port and battery replacement
Okay so I had this iPhone 6+ that would die really fast. Like it would be at 1%, I would plug it in and in a minute the battery life would display 100%.
I first replaced the battery. After the battery replacement, the phone turned on for like 15 seconds showing the Apple Logo. Afterwards, it turned off completely and never turned on again. I tried replacing the charging port as well to see if that was the problem. However, nothing happened once again.
I have an original brand new apple charger so the charger is not the problem. I have tried to put the phone in DFU mode and Restore mode and nothing happens. iTunes does not recognize the phone at all.
Any suggestions?
Score 2
Add a comment
1 Answer
How did you disconnect the battery and the charging port from the board? Did you use metal tools? Did you maybe go to deep and knocked something out of place? Have you tried putting the old battery back in? It can be a lot of things if you have a microscope look at the board o have customers sending in phones everyday to us because they did something wrong while changing something on the phone.
Add a comment
Add your answer
Nilsa Rodriguez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 159
