Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Logic Board, typical failure
So... I bought a 2011 MacBook Pro on eBay that said the logic board was failed based on advice from a buddy. I’m a novice, so please forgive me. I did the typical “put logic board in the oven” trick. I put a new SSD in it too. After a bunch of messing around, I was able to format the drive and install High Sierra using a bootable USB file I found from my windows. Everything ended up working out great and I was set! Keep in mind, I’m not a computer fixer, so this was a huge win for me! I went to open a program and the laptop started to just continually restart. I call my buddy and he says, yea the fix didn’t take. Go buy a heat gun and heat the GpU up. Long story short, I did, and I heated it up so much that components (resistors or diodes, I don’t know????) on the other side of the logic board fell off. I’m dumb, I get it. I have a great running laptop that just needs a working logic board/GpU. Every search I find wants like $450 for a new logic board, and it’s a 2011 MacBook, I already have enough money in. What is my best option to get this laptop up and running for an affordable rate. I’m willing to spend a few bucks, but not $450. Please help!
Add a comment
Chosen Solution
Since your logic board is probably far beyond repair and a used one is too expensive for your budget, the only alternative I see here is settling for a cheaper logic board. A dual core board, i5 2,4 or 2,53ghz or i7 2,66 is definitely cheaper than the quad and it fits your machine. Unless you need the Mac for demanding work tasks, it might be an interesting alternative.
Score 1
5 Comments:
Can u please send me a link on where to buy such logic board that will fit?
by
The boards from 2010 fitting your laptop are all marked as 820-2850, regardless of the processor used, thus you can choose between the different specs I listed above. Unfortunately I'm in Europe, I fix boards myself and I never buy working boards, thus I'm not exactly the right person to guide your purchase. I believe there are several reputable seller you can choose from in the Us.
by
I just want a logic board to get this thing running, not looking to do anything heavy on it. Just want a decent running MacBook Pro I Can run high Sierra on w my new SSD and 8gb ddr3 Ram
by
Any 820-2850 is more than just decent..with an Ssd is still quite an enjoyable Mac laptop, yet updatable until the latest Os.
by
So I bought a working logic board under the 820-2850 marking. Everything hooks right up until the battery. It’s a totally different connection, so.... do I just need a different battery? If so, what do I look for?
by
Add a comment
You are in a pickle here ;-{
Frankly, you can use a lower end 2011 logic board than the premium board like this one: MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board Vs the most expensive which offers the best performance: MacBook Pro 15" Unibody (Early 2011) 2.3 GHz Logic Board
While you could use the 2010 model boards their performance is less than what the 2011 models offer.
MacBook Pro 15" Unibody (Early 2011) 2.0 GHz Logic Board Image
Product
$149.99
MacBook Pro 15" Unibody (Early 2011) 2.3 GHz Logic Board Image
Product
$199.99
Score 1
Add a comment
Add your answer
h3kgwin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 623
