Model A1320 / 8 or 16 GB capacity
156 Questions View all
Question Closed
How do i fix the hold button (its stuck on hold) my ipod got wet
My ipod fell in a fish tank and will only turn on when connected to the computer, but the hold button is stuck on so it will not play music. Any suggestions on how to fix the hold button????
Add a comment
How do i revoke a password for the iPod
Add a comment
Wait until the ipod dries out.
Why won't the hold switch work? Did you lose it in the water tank?
You can pull off the top white plastic bezel. There should be a hold switch that comes out easily. Make sure it is in the right place. There should also be a small, red, plastic dot attached to the metal below that moves back and forth. If you don't have a hold switch you can take your finger, click the red dot in the other direction and it should remove the hold, if it is already on hold.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,021
