The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
375 Questions View all
Help.! My New nintendo 3ds XL can not turn on
This just happened when I unpacked my New nintedo 3ds XL, I tried to change the R / L button it had worked, in the last stage I want to install batre but accidentally overturned and when the light is blinking red, then I try to put it right and happen. !!!! My Nintendo can not turn on anymore, but I try to charge the orange lights still can burn.
the situation is like in the photo,
so what exactly happened ????? what should i do to fix it ?????
Please help
-Thank you very much
Add a comment
1 Answer
Most Helpful Answer
batteries dont need to be turned to install into the device, so im a little confused as to what exactly you mean when it stiopped working.
The orange light turning on means the board is receiving a charge signal.
i would take a multimeter to the leads of your battery, and make sure youre reading the desired output voltage.
then try the leads to the battery connector and verify it is tansferring to the board properly.
if these work fine, then it is time to move on to the power flex, and Sub PBA. make sure you have continuity on the power button, and that it is sending the signal to the main logic board.
if all of the above test fine, then you have narrowed the problem down to the main logic board.
Score 1
3 Comments:
The problem is I reversed installing batre (min and plus) and could not turn on anymore ..
by
due to the way circuits are generally protected from that, it shouldnt have caused an issue. but i would suggest going through my steps either way to verify the location of the issue
by
You've saved my life with this, I've been at it for hours and didn't even think of trying a new Sub PBA
Thank you
by
Add a comment
Add your answer
Abdillah Dxc will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 632
