Failed display assembly replacement now old and new display blank
I have a Late 2013 Macbook pro 15" laptop. My lcd cracked and I bought an entire display replacement from amazon. Cracked screen was still visible for 90% of screen outside the crack. I replaced the screen making sure the battery was disconnected and taking my time carefully removing all hardware. After installation the new screen was not turning on and I tried again to reseat all the cables but still no display. I then reinstalled my old cracked screen but now that is also fully blank, the apple logo is dim, and the flashlight behind the logo trick did not show anything. I have hooked it to an external display and the computer is as it should be via the monitor.
I looked through a loupe to see if anything wrong with the display power cable but don't see any bent pins or shorts. I do have a cheap multimeter but don't really know how to use it for this.
Does anyone know what the problem could be? Can the apple store be able to do anything about this?
2 Comments
To be clear here your screen was working but the cover glass was cracked Vs the LCD its self. You then installed a used display which was damaged but less so? Then you put the old back as the new one did not work. Now both show a black screen.
by Dan
My original LCD cracked. the glass was ok. screen was able to be used still except for a small black spot on the corner, I bought a used display from amazon and tried to install it, That install didn't work. Then I put back my original screen with the broken LCD but that is now completely blank as well.
by Tony V
