The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
90 Questions View all
My 97 camry starts in the acc on position but will not crank if I try
I have a 97 Camry its an automatic v6 it recently broke down after it Was running fine went into the store bought groceries came out acted like the battery was dead car wouldn't attempt to crank. Tried jumping it nothing happened. 5 days later I went with car trailer to pick it up put the key in turned the ignition to on. Position and it started but starter wont disengage now. I put a new starter in it still same problem all wire connections are tight battery terminals are tight totally clueless on what it could be
Add a comment
1 Answer
Most Helpful Answer
Dale Trivett it sounds like an issue with your ignition switch or the ECU. For an ECU error you would need to have it scanned. To check your ignition switch use the attached image and a multimeter and check for continuity as shown
Score 2
2 Comments:
Thanks i will try that out i forgot to add in that i recently changed the key cylinder too since the old key wouldn't turn the ignition anymore.
by
Dale Trivett that makes me suspect a faulty ignition switch even even more! ;-)
by
Add a comment
Add your answer
Dale Trivett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 230
