Repair guides and support for wireless and wired Apple keyboards.
Left Shift + E not working (Right Shift + E works)
Hello everybody,
I have a strange Problem with my second hand A1243 (With Swiss Layout) Keyboard.
If I use left Shift + E it doesn't do anything, but if I use right Shift + E it works.
Everything else works so far.
Has anybody any idea what that could cause?
Thanks in advance.
Sandro
2 Comments
did you spill something on it?
by
No, I just got it second hand. Perhaps the previous owner spilled something.
by
Add a comment
Chosen Solution
Hello Everyone
Sorry for coming back to you so late and thanks for your inputs.
It started working again. But I’m not sure on what the problem was.
I have two possibilities:
1) Because of my work I’m using various softwares that have system-wide shortcuts (like Spectacle for window rearrangement). I have reinstalled some of them. Maybe these shortcuts for english keyboards had a binding that was not working with the Swiss keyboard.
2) Around the same time it stopped working, I have updated my Laptop. While uninstalling the softwares mentioned above, I updated the laptop again and also reseted the NVRAM/PRAM.
One thing that stands out (I don’t believe it was the problem though) is that the the bottom left of the chassis of the keyboard had a small bump in it. Between the alt and cmd keys. I flattened it out with my fingers but I don’t think this was the problem.
Add a comment
Most Helpful Answer
Try left Shift for other purpose eg to Capitalize or other to check if it pressed.
If it is ok, you can change the keyboard layout in mac settings.
http://thetypingcat.com/howto/change-you...
Score 1
4 Comments:
I testet every other Left-shift Combination with the keyboard.
The layout setting ist also in Swiss-German (I tried German too).
It happens only with Left-shift + E
by
Strange! change it to English layout to check it. Also check it on another PC if it possible or check it on windows with boot camp or virtual machine.
by
The other suggestions are a lot of work for nothing. Do this: First, unplug then plug back in your keyboard (wired or wireless). Next, carefully examine the F keys on your keyboard to make sure none are stuck in the down position, especially the F12 Key. Tap the F12 key, then try your keyboard combination again. Is it fixed? If not, clean up (find instructions online) your F12 (or other F Keys), then try again to press the F key, then your troublesome keyboard combination (e.g., Shift+E).
by
Larry W Bradley I think you saved me. For me, it's the F3 key (Expose) on my A1243 keyboard. I noticed that sometimes when I use the external keyboard, it goes into Expose, and I figured I was accidentally hitting some shortcut, but it looks like the real issue is that F3 is kind of dirty and that is affecting Shift-E and Cmd-C somehow. I pushed F3 a few times, and now Shift E and Cmd C work again. I will look at these instructions for how to give it a deeper clean: Apple Extended Keyboard A1243
by
Add a comment
I’m having this exact issue. The computer is a 27” iMac, the keyboard is an apple USB keyboard with keypad. It’s only the letter E, and only with the left shift key. I’ve checked the system preferences > keyboard > shortcuts area and I don’t see anything there.
1 Comment:
Did you had luck with your keyboard?
As I mentioned above I updated the system, reseted the NVRAM/PRAM and looked at other software with system wide shortcuts.
by
Add a comment
Add your answer
Sandro Ciotti will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 41
All Time: 2,047
