Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4632 Questions View all
Trackpad won't move, like it's jammed in place
My trackpad is jammed and the only way it will function to drag and drop is if I use both hands and force it down really hard. It doesn't make the clicking sound when I push it. I haven't replaced anything or mistreated it, so I'm wondering how to get it to loosen up. Do I need to go get it replaced? Is that the only option?
1 Comment
Agree with @arbaman and @mayer. If you're tech savvy, it's easy enough to do yourself, but you could also find someone locally to do it. It's a very easy repair and shouldn't cost too much.
by
Add a comment
Chosen Solution
Check your battery for swelling. If swollen, replace it.
MacBook Pro 13" Unibody Late 2011 Battery Replacement
Score 4
Add a comment
Maybe you don't need to get it replaced, it would give the same problem even if something small ended up between the trackpad and the palmrest and got stuck.
If you want to give it a try and have the tools follow this guide to get to the trackpad and try cleaning small debris and see with a nail if the switch still "clicks". If it doesn't at all, trackpad needs replaced.
MacBook Pro 13" Unibody Early 2011 Trackpad Replacement
Score 3
Add a comment
Add your answer
Angela will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 18,196
