Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
broken Ear Phone Jack
I dropped my iPhone recently and now my earphone jack doesn't work. how can I fix it?
Add a comment
If you can hear good sound from the internal speaker , you can change that part:
Remove and reinsert another spare headphone set.
If not fix,
You must open the device. Use ifixit disassembly to access the part that is in the picture.
Remove and reinsert the flex cable as seen in the picture. and test it again.
If it not work buy an original / genuine replacement part and throw it in. You have good chances to work.
If also this not work , here it have Logic board Issue. Go with wireless Bluetooth headphones, which i hate.
Add a comment
Hello Sari,
The headphone jack on an iPhone 6s is part of the charger port assembly. Changing this flexible printed circuit board accomplishes changing the jack as well as the cable that leads to the jack.
Bottom Flex
You should also be replacing the adhesive seal each time you disassemble and reassemble an iPhone 6s. It helps with water resistance.
iPhone 6s Display Assembly Adhesive
If your phone's continue not to function after replacing the flex, you will need to bring your phone I to a local repair center to diagnose the issue.
Replace a lightning connector, headphone jack, dual microphones, or cellular antenna compatible with iPhone 6s models A1633, A1688, A1691, and A1700. Part #821-00078-08. Image
Product
iPhone 6s Lightning Connector and Headphone Jack
$19.99
This custom cut adhesive film secures the front screen display assembly to the case of an iPhone 6s. Image
Product
Add a comment
Add your answer
Sari Fein will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 146
