Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
Does a high resolution display out of i5 model fit in late08?
Hello ifixit comunity,
my Macbook Pro late08 (A1286) got some scratches etc. over the time. Since my last travel i have a grey shadow on the display and I want to replace it.
So I thought maybe I can get a higher resolution display. I found this display on ebay and I would like to ask is the connector the same in late08 and the newer i5 models?
Is the upgrade possible?
Greetings from Germany and many thanks in advance,
Hendrik
Score 1
1 Comment
So are you going to do it?
by
Add a comment
Chosen Solution
hen, although the connectors look very similar, your board/firmware will most likely not recognize the higher res display.
Score 1
1 Comment:
+ they do have to speak the same language.
by
Add a comment
I doubt it will be compatible, Apple most likely designed it to work only with it's original display, not next-gen higher res display.
1 Comment:
Hi.
Thank you for your Answer. The connectors look exactly alike.. I think I'll give it a try as soon as I find one.
Further answers are still very appreciated.
I will post again when I found "my" solution :)
by
Add a comment
Add your answer
hen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 1,104
