Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 Questions View all
Vizio 58" T.V. model number D58U-D3 has a Worsening blue tint
Hello, my issue is with a Vizio 58" T.V. model number D58U-D3. Over the two months the screen has been producing a blue tint in two different areas. The tint now covers almost the entire screen. I have tried to research this but the only thing I have come across is to replace the main board. Well, I ordered all the guts for this T.V. and replaced it all and the screen did not change at all, it has the same exact blue tint. Now the only thing I can think of since everything except for the screen has been replaced is that the screen is somehow just going bad somehow.
Now to answer some questions that I know will be asked. I verified that this issue happens exactly the same with HDMI, USB connected media, and with the built in Netflix and Youtube. I have checked the two ribbon connections at the bottom of the screen. The T.V. is 2 years old. The menus all have the same blue tint.
Thank You for any help.
Score 2
6 Comments
Mine is doing the same thing 2 years old. I am thinking its the backlight because when I adjust it it reduces the blue tint. I have read articles for other tvs where it was the led panels... Im looking into that repair
by
i called Vizio and they will replace it.I lost my reciept so im stuck with a blue screen.I will never buy a Vizio product again
by
I had this happen about a year later to my Vizio D-series tv too. It turned purple / blue tint to all inputs including the TV menu. There's also dark and bright spots around the screen. I've seen this on Phillips TVs at Wal-Mart.
by
The blue tint is caused by the phosphorous coating on the LED's becoming brittle, cracking, and breaking off! Darkness/dimness is caused by LED failure!
by
I paid 780 bucks for this tv from Costco. I really liked it . my daughter bought the 65 " version 2 months later and told me that my tv had a blue tint on all inputs. I CALLED THEM AND THEY TOLD ME THAT WAS NORMAL FOR THAT MODEL. 1 year later I won a new 65" Samsung and moved the vizio into my bedroom. I was amazed how blue the screen is compared to the Samsung. After I researched the issue on the web and found it was a common issue with these tvs.I contacted Vizio and they blew me off.
Trust me I will never ever purchase from or recommend this company to anyone.
by
Show 1 more comment
Add a comment
Most Helpful Answer
@nickbon that does sound like a panel issue. Post some images of what your display shows with your question. That way we can see what you see. Use this guide Adding images to an existing question for that. If it is the panel, there is not much that you can do. Replacement panels are pretty much non-existent and if you do find them, they are more than a new TV.
Score 3
Add a comment
The phosphor or yellow center on the backlight leds crumbles and falls off leaving you with a bluish purple tint to everything on the screen the telltale sign is when your tv is first turned on the vizio logo will have a blue tint and the black screen will also have a purple blue tint… search blue vizio on youtube you can see a vizio torn down exposing the defective leds … I have called vizio and they will not fess up to the defect backlights nor will they authorize any concession for warranty, I am waiting for the class action lawsuit to begin……. Also was at walmart recently and noticed some Phillips tvs that were blue on display failing before even leaving the store!!! Contacted shopjimmys for new led backlights to repair the set and was told this wasn't possible…. Wrong. They are defective leds from vizio
Add a comment
Any chance you still have the TV? I'd be interested in buying it.
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 35
All Time: 11,745
