Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
I disconnected my LCD screen when battery was still in. No backlight.
I disconnected my LCD screen on accident without removing the battery. I smelt a burnt fuse smell. When I use my new LCD screen there is no backlight. I checked the fuse with the small dot on it, and it looks intact. Do I need to replace the fuse regardless? Do I need board repair? Any help would be appreciated.
Thank you for your time!
1 Comment
Yes, I can log on to my home screen.
by
Add a comment
1 Answer
Chosen Solution
You'll need to test continuity of the fuse a visual inspection is often not enough.
But lets see if the backlight fuse is blown by using a flashlight shining through the Apple Logo. Are you able to see the desktop icons?
Update (03/13/2018)
Well, you're lucky! The backlight logic is damaged. Hopefully its just the fuse link.
At this point I think you'll need to visit someone who has the needed parts and micro soldering skills.
Score 1
1 Comment:
Yes, I can log onto my homescreen.
by
Add a comment
Add your answer
Daniel Castro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 46
