Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Brightness of screen won't change (won't get brighter)
I've just bought a late 2015 iMac 5k (used, sadly!), and there seems to be a problem with the brightness. I noticed fairly quickly that the screen isn't as bright as either my Macbook Air or the Thunderbolt display I was using previously. The brightness control only makes any difference for the first five "blocks", after that any increase makes no difference. I am running 10.13.3. Here are all the things I've tried so far:
  • Turning off auto-brightness (makes no difference). Night Shift is also off.
  • Resetting the PRAM
  • Resetting the SMC
  • Turning it off and on again!
  • Running diagnostics (no issues found).
Nothing has made any difference.
The screen is equally bright across all of it - no dark corners / sides.
Can anyone help me work out what's going on?!
Update (03/12/2018)
Other stuff I've tried:
- hooking up the thunderbolt display - mac controls display brightness no problem, and it's much brighter than the iMac display
- downgrading to 10.11.6 - same issue.
Score 1
3 Comments
i have the same issue with my iMac late 2013 after i installed the new High Sierra the device display played funny and brightness adjustment is not working.....still looking for an answer
by
Hi Stephen,
I have exactly the same issue - second hand 5K Imac (2017). Did you ever resolve?
Regards
Eamonn
by
The worst part about it,,,,Apple dont say anything, i just lost my iMac pretty much because it wont function like how it used to…and it is NOT CHEAP!
by
Add a comment
1 Answer
Most Helpful Answer
I think the best solution here is to bring it into an Apple Store and let them figure it out.
I haven't seen any of the newer 5k models have issue with a weak backlight as you've described.
Score 1
2 Comments:
My brightness won't work from the keyboard. I have to change it in preferences. The meter goes up and down but no change in the screen. I have a 2017 macbook pro that I bought last summer and have already had to have the keyboard replaces for other issues. For what we pay for mac they should be flawless- at least for the first couple of years.
by
Samantha - iMac's are different than MacBook Pro's
by
Add a comment
Add your answer
Stephen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 18
All Time: 7,829
