Brightness of screen won't change (won't get brighter)
I've just bought a late 2015 iMac 5k (used, sadly!), and there seems to be a problem with the brightness. I noticed fairly quickly that the screen isn't as bright as either my Macbook Air or the Thunderbolt display I was using previously. The brightness control only makes any difference for the first five "blocks", after that any increase makes no difference. I am running 10.13.3. Here are all the things I've tried so far:
- Turning off auto-brightness (makes no difference). Night Shift is also off.
- Resetting the PRAM
- Resetting the SMC
- Turning it off and on again!
- Running diagnostics (no issues found).
Nothing has made any difference.
The screen is equally bright across all of it - no dark corners / sides.
Can anyone help me work out what's going on?!
Update (03/12/2018)
Other stuff I've tried:
- hooking up the thunderbolt display - mac controls display brightness no problem, and it's much brighter than the iMac display
- downgrading to 10.11.6 - same issue.
3 Comments
i have the same issue with my iMac late 2013 after i installed the new High Sierra the device display played funny and brightness adjustment is not working.....still looking for an answer
by halfraid
Hi Stephen,
I have exactly the same issue - second hand 5K Imac (2017). Did you ever resolve?
Regards
Eamonn
by Eamon
The worst part about it,,,,Apple dont say anything, i just lost my iMac pretty much because it wont function like how it used to…and it is NOT CHEAP!
by halfraid
