The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
319 Questions View all
Why won't my dryer turn on, it shows wet status even when it's empty?
i have a Kenmore Elite Dryer HE3. The Dryer will not run after I push the start button. It just clicks off. I tried unplugging it and re-plugging it. I tried removing all the clothes to see if it will run even when it is empty. There is electricity going to the dryer and the circuit board. It just will not run.
2 Comments
The outlet is 220. I already unplugged it for over 5 minutes, and I reset the breaker. None of these worked. Thank you for trying to help.
by
Mine also lights up and when you press start it just goes to wet signal. I unplugged it. I took all the clothes out. Still doing it.
by
Add a comment
1 Answer
Most Helpful Answer
First unplug it for five minutes to allow it to reset. Next keep in mind that if it is being used in the USA it runs off of two 110 volt legs and may only getting one. See if you get an error code and let us know what it is.
Throw the main breakers.
Score 2
Add a comment
Add your answer
george jetson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 713
