Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
How to get out from recovery mode?
A customer ask me how to get out from recovery mode on a Samsung S6.
I´m not that in to Andriod and Samsung, so I´ll ask here :p
After a day outside the phone powered off and did not power on. When we got it on it boots in recovery mode. First message is "Recovery is not seandriod enforcing" in the upper left corner. After that it gets to, what looks like, recovery mode.
It says: "Your device will be in the Recovery mode trough the revery process. Tip: If the data recovery process is completed, but your device keeps in the froxen stat, please click "Exit recovery mode" button in the lower left corner on the interface, or directly close the program to make your device exit the recovery mode."
I can not exit of press any button tho... Can force restart it, but the same happens.
Here is two pictures:
Score 2
1 Comment
This is the only post I found about this problem and there is no solution
by
Add a comment
1 Answer
Most Helpful Answer
Looks like the customer was trying to either unbrick the operating system or retrieve data from the phone that may have been stuck in a boot loop or forgot the screen lock.
Anyway, what needs to be done is the firmware reflash on there.
How to do it linked here:
https://updato.com/how-to/how-to-install...
Just make sure you flash HOME_CSC if you want to keep data on the phone, not the non CSC one (This is at least for the S7 models and higher).
Score 2
2 Comments:
Thank you!
Will test this.
by
did this work?
by
Add a comment
Add your answer
alex will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,502
