powers on but no sound...
ive got a couple of ipod videos and they appear to be OK, turn on and play music but there is no sound....i tried a new replacement headphone jack but still no joy...could it be logic board??
steve Connolly there are some issues with some of the boards. First you should tell us if it syncs properly and if you can access your files with music while the iPod is in diskmode. After that you want to place your iPod into diagnostic mode and see if you get any errors (you may get a FW error). If none of that shows any issues, you may have problems with the audio IC. In the case of your iPod I am leaning more toward this problem. This particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the ipod, almost between the click wheel and the bottom corner. If you should get sound by doing so, then you only have very few options. One is a new logic board, the other one is to reflow your old logic board.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 77
1 Comment
Do you have an iPod dock? If so, test to see if it plays sound through the dock. There are Bluetooth adapters you can find on Amazon that plug into the dock connector, so if it works, buy one, and a pair of Bluetooth headphones, you will be able to listen to music that way.
Bluetooth adapter: https://www.amazon.com/s/ref=nb_sb_noss?...
by Daniel Korzhenevich
