Drain coolant, how catch in pan, is only a plug to remove, will drain
Need to drain coolant, how to catch coolant in a pan, is only a plug to remove, no fitting to attach hose to lead into a pan, will drain all over. ??
You probably will need to remove some of the plastic splash guard panel things under the front of the vehicle to drain the radiator effectively. Me I drained mine by running into a wild hog at 70 mph a couple of years ago.... Needless to say the radiator drained instantly, airbags deployed required a tow in. Car was totaled by insurance :(
You remove the 1 piece splash shield, then radiator drains onto cross member and you clean up the mess. No alternative. Needs large catch pan. Messy.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 81
