Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Why is my screen black?
I was on Facetime and The screen went black, I thought it was nothing big. I tried resetting it but nothing occurred I even went to a shop to see if it was the screen but it wasn't, I don't know what the issue.
Add a comment
1 Answer
Chosen Solution
If a repair shop confirmed that the screen was not the issue (did they try another one?), then your issue is on the logic board. I'm a little surprised that the the shop was not able to tell you if your problem is backlight related though as that is a simple test.
Does iTunes recognize your phone? If so, plug your phone into an iTunes enabled computer and shine a bright flashlight on the screen. If you see a dim image, then you have backlight issue. If not, then it could be an LCD driver issue.
If iTunes does not recognize your phone, then it could be a wide range of issues. Ideally, you will need to have this phone looked at by a micro-solderer so that it can be properly diagnosed.
Score 3
Add a comment
Add your answer
john valencia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 71
