Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2264 Questions View all
iPhone 7 freezing since screen replacement
Hi Guys,
Wonder if anyone can shed some light on this.
Replaced an iPhone 7 screen the other day. When i changed the screen and powered it on the first time, the screen was unresponsive, so i had to lock it and then the screen came back to life and it worked fine when i tested it. However the customer left it for a couple of days and advised me that it kept freezing. So i went back to change it for another screen but the same thing is happening.
I will note that the first screen i used was a copy, but the second screen was OEM.
Thanks in advance.
Add a comment
1 Answer
Ok, this is going to sound strange, but I have seen this happen on 3 iPhones (2 7 plus and 1 6s plus).
Does the customer have a pass code on? I have seen where if there is no passcode the digitizer wont activate until it's locked then unlocked. This was using an OEM screen as well.
1 Comment:
Yes, the customer has a passcode.
by
Add a comment
Add your answer
chilun will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 443
