iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
LCD TEMP Sensor not work
And the iMac original write :
593-1029 A 50/09 W On-semi
This replace sensor has the same problems after I try to reset SMC reboot iMac, remove ram, e.g.
I try to buy a new thermistor 2n3904 and solder it. But, nothing happens...
Any help solution there?
Add a comment
1 Answer
Chosen Solution
Lets start afresh here as your question is very confusing.
Describe your problem not what you think the solution is as you may not be doing the correct action.
  • Is the system working at all?
  • Is the system shutting down?
  • Is the screen turning off?
  • Did you run diagnostics?
  • Did you replace the HD and/or add RAM?
  • Did you make any modifications?
Add a comment
Add your answer
hacker tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 146
