Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 Questions View all
Why does my screen go black when I turn the TV on but sound works?
Tv works then you turn it off and try to turn it back on and sometimes it is just black after it flashes the tv logo. We unplug it for a bit and plug it back in and turn it on it works fine. What's going on?
Add a comment
1 Answer
Chosen Solution
@sheliamayfield you do want to take a look at the power board and the main board. It is always difficult to diagnose intermittent errors. this could be an issue with bad capacitors on the power board, main board or even t-con board. It could also be the backlight array. You do want to go ahead and remove the back of your TV without touching any of the boards (unplug it of course). Then post some good images of your boards with your question. That way we can see what you see. Use this guide Adding images to an existing question for that. You should also let us know what exact model your TV is.
Score 1
Add a comment
Add your answer
Shelia Mayfield will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 500
