Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
Broke SMD Capacitor (and lost it) and need vol.ic detector
Hi, while ago usb cable burned charging port, i replaced connector and it kinda worked,took 6 hours to charge and usb wasn't detected, ordered new daughterboard, replaced but still same result, i did research and found out that it was IC-VOL. DETECTOR's fault (sec code: 1203-008487. design loc: U8010)
looked up and found kinda simmilar chips on ebay and samsungparts but not sure if it's the one i need
but there's another problem
there are some protective metals above chip, i tried to take them off to see name clearly and... i accidently broke of one of capacitors: 9801C
can anyone tell me what capacitor it was? if it's even capacitor.
if i can't find these 2 parts my phone's basically dead XD
Score 1
Add a comment
1 Answer
Chosen Solution
Sinnerman the part you broke off is actually C1089 make sure that you look at the schematic the proper way otherwise you may end up getting the wrong part. 2203-007796 is the Samsung number and it is a 1000NF (1UF) 20% 10V X5R, in a 0603 package. Not sure about the ebay seller so you should contact them and give them the Samsung number and have them tell you that it is the right part. The part by Samsung part number is available at places like this and even on here. It is also available at places like Mouser.com with exact specs but for a whole lot less money.
Score 2
4 Comments:
For the capacitor, 1000NF is an non-standard way to spec a capacitor and not every supplier will list it as such. It is the same thing as a 1uF (or 1MF) so that may help the OP in locating it. This can also be found on sites such as DigiKey and Mouser.
by
@refectio you are of course absolutely right. that is what happens when one uses Samsungs untranslated parts lists and uses online translation services ;-)
Thanks for clarifying this for the OP
by
thanks a lot <3 really helped me
by
lol i just realised text was upside down xD and it copied upside down as well, thanks again
by
Add a comment
Add your answer
Sinnerman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 580
