Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Replacement Battery Losing mAh Fast
I installed a new Battery into my iPhone 6 about a week ago. Now, usually this wouldn't bother me, but the battery reading software when I first installed it said it had 1750 of 1810. Which is not much of a difference but still a fluctuation for a battery. Now, 14 cycles later it is reporting that it can only handle 1650 of 1810. And I will unplug the phone and plug it back in and it maybe will go to around 1670 and sometimes lower to around 1610. Is this normal to see in a battery for fluctuations in capacity? Or should I order the warranty replacement?
It was a company off of amazon, probably not the best quality battery.
https://www.amazon.com/gp/product/B0769H...
Recently I replaced the iPhone 6s Plus battery, but ordered the parts from iFixit, and it has a maximum capacity of 2865 of what it should only have 2750 mAh.
Add a comment
1 Answer
Chosen Solution
Batteries are strange beasts; you can't get too caught up on what the exact capacity is at the outset. However, capacity trending down at a rapid pace is cause for concern. You are already down to 90% of capacity within a week.
You should contact your seller and see what they can do for you. They may be willing to replace it.
Score 2
1 Comment:
Figures, I thought something was up. Thanks for the help. The seller did agree to send a replacement, I just wanted to make sure I was not over-worrying and making them replace a perfectly good battery.
by
Add a comment
Add your answer
Noah Smith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 8
All Time: 450
