Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1200 Questions View all
bluetack stuck in speakers :(
Hi guys
stupidly i pressed on the bluetack a bit too hard :( and this got stuck in my iphone x speaker grill.
what is the most safest way to clean this? :/ its driving me nuts!!!!!!!!! this phone is brand new and hardly used.
Add a comment
You're going to want to use a soft bristle toothbrush and try and get it out. Another option is a toothpick but be gentle so as to not damage anything. And who knows how long it will take, but be patient take your time and just work on cleaning it out. Why were you pressing glue on it in the first place?
3 Comments:
Hi mate
Thanks for the quick reply .
To be honest, I just wanted to remove the debris stuck onto the speaker mesh. And stupidly I pressed a wee bit too hard onto the speakers with the bluetack.
Mate, should I let that bluetack stuck in; to dry out and then use the bristle ? Or should I try to scrape it off right now ? Since it’s still goey around in the edges of the speaker mesh.
Your input is highly appreciated . Cheers
by
Sorry for the late reply. But in all honesty I’ve never encountered such a sticky situation (pun intended) but yeah remove as much of the goey portion as you can, and whatever is left when it is dry attempt to brush out. When removing the goo ensure you don’t push it into the mesh further.
by
Did anything work mate got the same problem with my airpod I put blue tack to clean and I’ve got it stuck
by
Add a comment
Maybe try a little hot glue. You'll never get it out with no bristle brush.
Add a comment
Add your answer
Zohaib Shaikh will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 47
All Time: 5,783
