Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Which direction to turn set screw?
Hi. I know this is probably an extremely dumb question but I'll ask anyway. I have a trackpad set screw that is stripped. I know the old adage "righty tighty lefty loosy" however with the set screw I'm a bit confused. With the unit turned upside down and the trackpad closest to me with the clutch cover in back which way do I turn the screw in order to remove it.
Again I know not a real intelligent question but an answer would be most appreciated.
Thanks.
Add a comment
1 Answer
he screw shouldnt be removed its a setting screw for adjusting the click of the trackpad is there a reason why you want to remove it ?
2 Comments:
Sorry should have been more clear. The set screw s stripped which is why I want to remove it.
by
Yes I understand but there is no way to remove it from what I know without causing more damage its only supposed to move a few turns left and a few right.
by
Add a comment
Add your answer
Robert Cates will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 272
