High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 Questions View all
Ipad pro 12.9 no response..
Hello guys..
I need some help. Does anyone knows the problem with that...?
I’ve tried the new screen for ipad pro 12.9.
After putting two connectors on I pressed the power button but there was no response.
I could see the battery sign on the screen after putting on a charger.
Few minutes later checked the ipad, no response and the charger cable was little bit hot..
I found that something was missing on the screen connector.
But I’m very worried that the ipad was also damaged. I cannot check with old screen and new screen till next week..
Is it the screen problem or the ipad?
Add a comment
Chosen Solution
Did you isolate the battery before disconnecting the screen (see here)?
I am concerned about the damage you see on the connector. Can you post an image (add it to your question)? That and a "hot" cable. Sounds like there may be a problem with the charging circuit.
Go back through the guide linked above and double check your work. Report back with any findings.
Score 1
1 Comment:
The connectors on the logic board look okay but the ones on the flex look damaged, although that could just be caused by the blurry picture.
by
Add a comment
Thank you so much for the reply. Here’s the photos. I hope it’s just screen problems...
Add a comment
Add your answer
William will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 369
