Repair guides and support for your Samsung TV.
2614 Questions View all
Standby light is not on and tv will not turn on
I have a Samsung LED tv model# LN32B360C5DXZA that was working fine one evening but the next morning wouldn't turn on and the red standby light was out. I ordered the power supply board and replaced it and it does the same thing. When connecting it the standby light comes on momentarily and then goes out. I've tried the 30 second holding of the power button with no luck. One thing I have noticed is that even though I do not have the red standby light and tv will not turn on the Digital Audio Out (OPTICAL) plug in will have its red light on.
Score 1
2 Comments
Ricardo Medina what outlet do you have it connected too? You checked the outlet? you checked the power cord? Post some images of all of your boards with your uestion. Use this guide Adding images to an existing question for that so we can see what you see. With the new power board, have you checked the power on the board anywhere? you checked on the fuses?
by
The outlets work cause I have another tv hooked up right now and I tried the cords with the other tv and it worked to. I'll post the images as soon as possible, thank you for your replies.
by
Add a comment
1 Answer
Most Helpful Answer
Ricardo Medina start with this:
Check the various cable connections first.
• Check to see if there is a burnt or damaged cable.
• Check to see if there is a disconnected or loose cable connection.
• Check to see if the cables are connected according to the connection diagram.
Check the power input to the Main Board.
Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see.
Score 2
Add a comment
Add your answer
Ricardo Medina will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,738
