iPhone 7 stuck in boot loop after screen replacement
I have an IPhone 7 stuck in boot loop after screen replacement.
I already tried to restore, didn't work.
Tested battery and the screen on a different phone and it works fine.
The only way I am able to boot up the by disconnecting the screen assembly completely and iTunes will recognize the phone and it seem to work fine.
How would you fix this issue?
4 Comments
No, I will update the thread if I do
by oliverkoppel
Please do. I am having the same problem with 2 7's
by cd70451
I had the same issue with a 7...I was replacing the factory Apple screen with an aftermarket...started boot looping upon installing new screen...disconnected the screen and restored entering DFU mode...thought I fixed it...nope. Connected the screen (aftermarket) back and it started boot looping again. So frustrating.
by musick.jesse
I have a iPhone 7 with a broken home button, apart from that it was working fine, it is stuck in a boot loop due to the home button. Is there any home fixes for this? Even just a way to get it to turn on?
by Dylan McLaughlin
