My tv won’t turn on.
My sanguine hdmi tv will not turn after being without power for 5 minutes. Red LED light is on showing that it has power to it but tv doesn’t work.
@elizabeth54 what exact make and model is your TV? The Sanguine doesn't look like a know brand. If nothing else post some images of the the label from the back with your question. Use this guide Adding images to an existing question for that so we can see what you see. Use the same guide to post some images of all of your board that your TV has after you remove the back. The symptoms you describe could be a bad power board or a bad t-con board. You will need a multimeter to check a few things. Let us know what TV you have and if you are ready to get to work :-)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 13
