Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 Questions View all
Why is my Pelican Standard Controller for PS1 not working at all?
I have this Pelican Standard Controller for PS1 that doesn't work at all. I got it from a lot of broken controllers on eBay. I don't know the item's history behind it. I plugged it into the PS1 and tried testing it on Tony Hawk's Pro Skater 2. None of the buttons work at all. I am assuming that there's a break in the cord somewhere, but I'm not sure. Could you guys please help me repair this controller? Thank you and have a nice day.
Parker
Score -1
Add a comment
1 Answer
Chosen Solution
To test the wires you will need to perform a continuity test. For that you will need a multitester/multimeter. Most of the modern ones if you put them on the lowest OHM setting will produce a sound if there is good continuity. You will need to take the controller apart. Follow where each of the wires go from the cord to the board. On each wire put one of the test probes where the wire is soldered to the board, be sure you are touching metal. Take the other test probe from the multitester and run it across the pads on the other end of the cord if you hear a sound the wire should be good. You will have to dot his for every wire. If you have one that doesn't give a sound, you found your bad wire. The only 2 wires I can think of that could cause none of the buttons to function is a ground or a voltage reference wire.
Add a comment
Add your answer
Parker will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,212
