Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Internal display doesn't work on Windows, only Mac.
So this is a bit of a weird one,
I have a Macbook Pro Retina Mid-2014, The Internal LCD of the laptop only displays when it's running Mac.
It will boot up fine into Mac and works 100%, but when i boot into Windows all i have is a black screen unless i plug in an external monitor. (The internal screen stays black and undetected by windows)
I believe it could be a driver or software issue, how would i go about putting that to the test?
Add a comment
1 Answer
Most Helpful Answer
Have you run the Bootcamp wizard in OS X and created a USB stick with Windows drivers on it? If you haven't create one, then boot into Windows with the monitor attached, and then install all the drivers.
Score 2
Add a comment
Add your answer
James Final will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 65
