My phone is stuck in recovery mode
My phone is stuck in recoverty mode and itunes keep giving me error number 4013, i even tried with 3utools but it is stuck at 19% in restoring
Did anything happen to the phone prior to this?
Error 4013 on the iPhone 6 can be a corrupted NAND IC. That would require a micro-soldering repair and re-programming of the NAND. It also means data loss.
However before going there, you could try ReiBoot to see if you can kick it out of recovery mode.
i have had error 4013 and i was able to sort it through itunes, when recovering when it shows the progress bar start under the apple logo on the phone unplug the cable from the phone and plug it back in straight away
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 8,696
3 Comments
I don't know, received the indian charachter and then i phone could not boot up, so i tried to restore and update my phone via itunes and it always game me the errore number 4013.
by Ivan Valentini
have the same problem i'll try your solution.
When i try to update via ios i select the package, the it says waitng for the phone but the phone gets disconnected and it goes back to recovery mode
by Ivan Valentini
In my case the bar under the apple logo does not appear, the phone disconnects earlier and the operation fails
by Ivan Valentini
