Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
592 Questions View all
Won't charge, will only startup while plugged in, very slow
Hey there,
Really hoping for some answers or suggestions after some failed attempts of fixing my MacBook. I first had charging issues a few years back when my oem charger went on me. I used a non apple charger with no issues for a while and then that one slowly went with periods of no charging ( I would have to jiggle it around the port to start charging). Eventually it stopped working and my computer died. After a bit I bought another charger but my MacBook will.no longer charge. When plugged in the MagSafe will go green, I turn my MacBook on, but startup is extremely slow. My cursor is glitchy and jumpy, and my battery does not charge above 0. I have done an SMC reset with no luck. Possible battery replacement? From personal experience if I were to bring it into Apple would they give me a decent layout of what's going on or just try and charge me an arm or a leg? I would love to get it running again, upgrade the ram and run high sierra for hevc
Thanks for any help it is much appreciated,
2 Comments
I think I may have found the problem... surprised it even turned on for me. Also fixed my tack pad issue. Thanks for the help
[image|1348803]
by
What was the problem?
by
Add a comment
1 Answer
Chosen Solution
I have seen the slowness with no charging with dead ISL6259 charge controller chips. Could vary well be the battery though. I would order a new battery, Take around 5 min to change and you can find a tri tip screwdriver in the electronics repair kit that they sell at Lowes and change the battery. If it still does not work, it is a board level issue and needs to go to someone that can repair a motherboard. There are several in the US that can including myself. Don't go to Apple, they probably will tell you your machine is obsolete and not help you at all.
Score 3
2 Comments:
Awesome I will give the battery change a shot. Do you believe it would be worth getting a new charger as well?
by
I doubt it will help. As long as you have a green or orange light it's fine
by
Add a comment
Add your answer
Devon stewart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 1,988
