The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Questions View all
Washer doesn't fill with water on rinse cycle.
Kenmore washer does not fill with water for rinse cycle
Score 4
1 Comment
What colors should I expect on Inglis Washing Machine ITW4300XQ0
by
Add a comment
Chosen Solution
If the washer drains after washing but will not fill in the rinse cycle then checking the pressure switch would be a good idea. If the tub is empty you can remove the plastic hose, give the switch a thump and reattach the hose. Does it fill now?
If not then you can remove the violet wire and tan wire from the pressure switch and join them together with a small piece of insulated wire.
Remember to unplug the washer first before attempting this.
With these two wires connected the washer will fill if the pressure switch is the problem.
Score 7
5 Comments:
Did that and it worked!!!!
by
my wires are purple orange and pink ???
by
Remove which plastic hose?
by
@Rey “Manzo” Manzanares
There is a plastic hose that goes from the bottom of the tub up to the water pressure switch in the control panel.
As the water rises in the tub it also rises in the hose and this increases the air pressure on the switch, which has contacts that close as the switch operates with the ever increasing pressure and then it shuts off the water at the required level.
by
This, if the washer fills to wash, but rinse is less than small load? Inglis ITW4300XQ0?
by
Add a comment
Found it to be the drainage hose was too far in the
drain pipe. Pulled out the drainage hose . I immediately heard a lot of gurgling and water started to drain
ran a cycle, and it worked like it should
so, pulling the hose out of the drain, and re-seating it,
resolved the issue
Score 1
Add a comment
Add your answer
Cindy will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 59
Past 30 Days: 264
All Time: 28,728
