Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
799 Questions View all
Can a "thin" hard drive be put in a "thick" case?
I've got 2 sad iPods that I am hoping to turn into one working one.
The hard drive works great on my Model# MA002LL which is in a thin case, but the headphone jack will only play one headphone or speaker. I have a SquareTrade warranty on it but they say they can't replicate the problem so won't fix it.
I have a thick case Model# MA147LL that the sound is perfect on, but it gives me the sad iPod logo 90% of the time.
Because I'm trying to go from thin to thick, will the MA002LL hard drive work in the MA147LL case? Are there any weird mods needed to make it work?
I've swapped parts on iPods before so I'm comfortable doing the dirty work, but I want to make sure the parts are compatible before I try.
Thanks!!!
Add a comment
1 Answer
Chosen Solution
@hellziggy yes you can. All you have to do is to add some material on top of the HDD to compensate for the smaller thickness. Otherwise it will kind of move around inside the iPod and potentially cause some damage. I used some thin anti-static shipping foam on one of my replacements and have had no issues with that.
Score 3
1 Comment:
Worked like a charm. Thank you!
by
Add a comment
Add your answer
Sharon Snyder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 126
