Guides for the Wi-Fi version of the iPad Mini 3 (A1599). Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
61 Questions View all
Should I replace the touch screen FPC connector?
So, last year i have replaced the ipad touch screen. Unfortently doing that i kind of broke the FPC connector on the motherboard. Some of the "gold pins" came out, but none of them are in the same column. I mean, with the multimeter i checked that pins on the same column are shunted, so in that time i stayed with the idea that should not be a problem.
I reasembly the ipad and every line and column on the touch screen worked great.
This days the touch screen started to manifest some ghost problems. I wanna make a replacement again but before doing that i want ask you guys for your help. It's my
thought correct about the connector ? Or should i replace also the connector? It's intencional the pins are shunted for this type of problems ? Or they should shunt something in touch screen connector itself (not on motherboard)?
Best regards,
Update (03/02/2018)
Here is a detailed picture!
Add a comment
1 Answer
Chosen Solution
A picture of the damaged connector would help us determine whether or not the pins are important. Several pins are for ground and some are for the sleep/wake sensor. The rest are for the actual digitizer itself.
In an ideal world, you should have the connector replaced but perhaps you are lucky that the damaged pins are not critical.
Score 2
2 Comments:
Ok, thank you very much for the help. When i open the ipad, i will post a picture.
by
In the mean time, where i can find the schematics for this connector ? I mean for the ipad mini 3 ?
by
Add a comment
Add your answer
julioficabem will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 806
