Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Questions View all
iPad randomly restarting and WiFi grayed out
Hello, my problem is my iPad will randomly reboot, when it comes back on the WiFi will be grayed out and I am unable to turn it back on. Only after several restarts does it work properly....for a little while. I have already replaced the WiFi antennas and factory restarted it so that can’t be the problem. The problem started when I tried to use my aunts charger on my iPad, a charger that I didn’t know was a fast charger, my theory was that it overloaded the iPad with power. Don’t know if that’s the case but what ever it is, how can I fix this?? Thank you in advance for any help you can provide.
Add a comment
1 Answer
I have the same problem with an iphone 6, I also replaced the antenna and it’s doing the same... In my case, my phone got a little wet from the rain, and it started to behave this way, so maybe an overshoot in current is causing it... were you able to fix it?
Add a comment
Add your answer
Steven will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 304
