The dryer won't start
The dryer will turn on, I can select the cycle I want, and when I push start - the
"sensing/revising est. time " light comes on and the dryer won't start. No error codes are displayed .... any ideas?
First try unplugging it for five minutes then plug it back in. This allows it to reset. Then see if it will work or give us a code.
Unplugging did not work, nor did it give a code. Another site said it might be the fuse?
Same situation. The code that I get is PF (power failure). The light goes on when the door is opened and I can select load and the start button beeps when pressed but the dryer will not start. Replaced the thermal fuse thinking that was the likely cause. Any help here is greatly appreciated.
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 56
All Time: 2,191
