Screen only works when applying pressure on a specific spot. With pic
Hi, so i got an macbook air 13" My problem is related to the lcd screen. When starting the mac the screen is either completely gray, white or has lines scattered around.I at first thought that the lcd might be broken.
But if i apply pressure on a specific spot (pictures added at bottom) The screen comes back as normal. I did open the mac to see if the lcd flex cable was loose/took it out and checked that it was firmly seated. But this did little to nothing i think, as the problem was still there.
So my question is: Is this caused by the flex cable ? Or can it be something else ?
Im guessing its some problem with the flex cable going around the bezel of the lcd, and it needs to be changed. Though if i understand right, its really hard to do ?
I have no warrenty left on the unit, so it would be nice if i could repair it myself and continue using it.
