No pod required, single serve coffee brewing system with built in frother. Coffee drinks that can be made hot, iced, or other specialties and from a one cup serve to multi-serve. This device can be identified by its model number CF111 30.
Cleaning light won't go off
The "clean" light always goes back on even I just did the whole cleaning and flush cycle. It happens like weekly or daily. I think it's a faulty programming there. Is there any way to disable the light by modifying the circuit board or reprogram it?
Score 4
Add a comment
https://m.ninjakitchen.com/include/pdf/c...
Add a comment
I finally figured this out after 3 of these machines…there huge buildup of calcium in upper passageway, between the silicone hose and the shower head. Take pump off of heater, blow from shower head with compressed air. Clean out heater really good, then reassemble. Run a clean cycle however you like.. Should be good for another year.
Add a comment
Add your answer
infinity_bless will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 10,329
