Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Addition of HD to SSD model?
Hi I have a Factory 1TB SSD iMac
It has just been opened for warranty work and I noticed there is alot of room for an addition hard drive. It needs to be opened again so I was going to get the tech to chuck it in at the same time.
The question I have is
Does it have the OEM cable for the HDD being a factory SSD model?
If it doesn't Can it be purchased seperatly and added?
Thanks heaps!
Add a comment
1 Answer
Chosen Solution
You'll need to get the needed the custom SATA/Power cable, an adapter frame to support the 2.5" SSD in the 3.5" drive hollow, and you'll need the OWC in-line thermal sensor as well.
Replace a broken or damaged hard drive cable for your Late 2014 or Mid 2015 iMac Intel 27" with this part to fix issues with hard drive power and SATA connection. Image
Product
iMac Intel 27" 5K (Late 2014-Mid 2015) Hard Drive Cable
$19.99
Score 1
Add a comment
Add your answer
Franklin Hamilton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 103
