4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Phone is not turning on after screen replacement
I replaced the screen on an iPhone SE (including front camera/earpiece/sensors etc), but used the original home button for the Touch ID. I have since tried to turn on the phone. I have not had any response from the screen. There is no image on the screen (new, old and also a spare screen), there is no sound from the phone (not even in earphones) and also I am not getting any vibrations when switching the mute switch or plugging in the phone. The only activity I am getting is that my PC is recognising the phone as a USB device and connects as a drive (I cannot see files as I cannot unlock the phone with the passcode). Please help.
Thanks.
Add a comment
1 Answer
Chosen Solution
Did you disconnect the battery prior to removing/re-installing the screen assembly?
Failure to do so can blow the backlight circuit, which would make the screen look black. To know for certain, shine a bright flashlight on the screen when you connect it to the computer. If you see a dim image, then you'll know that the backlight circuit on the logic board is damaged. That would require a microsoldering repair and is not DIY.
Score 1
1 Comment:
Hello. Thanks for your quick reply. I cannot see any faint image on the screen at all and I am not getting any sound or anything similar either. Any further ideas? :(
by
Add a comment
Add your answer
Nathan Goldsmith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 67
