Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
Laptop won't stay on unless it's hook up to the charger
My laptop won't stay on unless it's hooked up to the charger. Once you unhook it, the laptop shuts off! When it's hooked up it runs fine! Does it just need a new battery or what??
Add a comment
Double check to make sure you battery is seated properly first. But going off your description of the problem you are having a new battery would most likely fix the issue since it works fine while connected to a charger and shuts off after removing the charger. This does sound like a faulty battery and I would recommend replacing the battery to fix your issue.
Add a comment
Your battery may need replaced. Until you can get it replaced, just keep it plugged in while you're using it and it will stay on.
Add a comment
Add your answer
Justin Davis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,517
