Screen off Over heated and dead
Can I get the data's ? How I can fix my phone please help me . Thank you
ARSHAD nk the heating up is an indication that something is shortening out. You said the body is heating up so my first suspect would be the battery. I'd go ahead and use these guides iPhone 6s to replace that. While you have your phone open, take a look at other components and see if there is some obvious damage also focus on the display and the display connector. Until you open it up and take a look, everything will only be a guess.
Ok any way thank you all
Let the phone sit for an hour or so at room temperature and see if it turns on again.
did you see anything like this warning at some point?
Thank you for your reply
No warning suddenly screen then start to heating then maybe after 20 minutes dead.
did you EVER drop it in liquid?
No I was using while it's happen
Your native language is not english (correct me if I am wrong). I can try to use google translate if that's easier for you.
tu hablas espanol?
No you can answer me in english
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 275
3 Comments
ARSHAD nk what do you mean by that "Screen off Over heated and dead" What get's hot? Does this "warning suddenly screen then start to heating then maybe after 20 minutes dead" mean you get a message on the screen? Does your phone work normally for those 20 minutes?
by oldturkey03
suddenly the screen off and the body start to heat .Maybe around 20 minutes it's working without the screen but after that it's turned off automatically then now I can't turn on
by ARSHAD nk
Ok so no water damage, Have you tried connecting it to a laptop, if you're only worried about your data?
by Zerocool278
