Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iPhone 6s screen doesnt work after water damage.
Phone got in bath but a little bit as my GF said. Not fully submerged. It worked for two days, then the screen stopped responding but everything else worked fine and still is. It can be turned on. The vibration works and all that. Im wondering if screen replacement will make the trick. I will try to open it and clean it with alcohol pads a bit. Here is a pic of what the screen looks like. http://tinypic.com/view.php?pic=8voge8&s...
/I dont know how to add pictures here, so i uploaded in tinypic. typing from phone. Thanks i advance./
Edit. - opened the phone, cleaned with 70% alcohol but i didnt see any corosion and the water indicators looks fine. I ordered new screen it will be here in about a week. Will update later. I left the phone open to let it dry out even more, even tho it was dry anyways.
Add a comment
1 Answer
Chosen Solution
For the screen, you may want to test cleaning the cables of the LCD before seeking a replacement.
@prohorovs Here are some notes regarding liquid damage.
Courtesy of @oldturkey03
The very first step I would take is to disassemble your phone. Use this teardown to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You absolutely must remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair.
Repairing iPhone Liquid Damage
iPhone 6s Teardown
iPhone Image
Guide
Difficulty:
Difficult
1 - 2 hours
iPhone 6s Image
Guide
iPhone 6s Teardown
Difficulty:
Moderate
Score 3
1 Comment:
@juax excellent answer!!! :-))
by
Add a comment
Add your answer
Arnolds Prohorovs will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 694
