Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121 Questions View all
Question Closed
Won't boot after repair
Replaced the hard drive re-formatted it and got it booted up
Still had noise-replace the fan assembly and DC-in board (broke one while removing).
Re-assembled and no boot
no chine, no screen, no hard drive spinning, no nothing
tried: pulled apart and checked all of the connections
removed battery to boot
reset PMU, tried target disk mode. boot from external hd, boot from cd, connected external monitor
only responses -superdrive spins sometimes, caps light works, ac adapter green
not sure what to do next?? what did I break??? Everything looked fine and in its' place. TIA
6 Comments
Yes it was running before replacement
checked the keyboard connection, seems fine
got the dc in board from ifixit, don't have a multimeter
can't use the old one sheered an ic off the bottom taking it out
what kind would i need and what would I be checking/looking for?
by
Part was correct, ordered the multimeter what and where do I check?
by
Would you mind telling me what the part number was and giving me the last three letters of your serial number.
by
IF155-008-1 part #
MVZ is the last 3 letters of the serial #
by
Apple PowerBook G4 1.0 17" (Al) Specs
Identifiers: 17-Inch - M8793LL/A - PowerBook5,1 - A1013 - N/A
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
If it was running before you replaced the fan and DC-in board and you replaced the DC-in board, then look to the change you made. Recheck your installation of the DC-IN port, test it with a multimeter. If the old port will work at all, give it a try. Next check your keyboard connection to the logic board, you may not be getting a start signal.
Score 2
4 Comments:
Here's a multimeter that will do. First thing I would do is check your model number vs the part number for that machine and what you received. Digital Multimeter
by
can you give me some information on what/where to check with the multimeter please? i will be getting it today TIA
by
This will give you a good idea of where to test, you may need to extrapolate some: http://screaminglight.com/projects/techn...
by
see my above note about what finally fixed the problem. Thanks for you help Mayer
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 885
