Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2693 Questions View all
iPhone only connects to LTE band 20, no 2G, no 3G, no LTE band3,7
Hey,
i got some problems with an 6S, iOS version 11.2,11.2.2,11.2.5,11.3 beta 1
the phone was bought 2 years before in germany.
used with Telekom/T-Mobile in Germany
Telekom uses 2G on 900 Mhz, 3G on 2100 Mhz, 4G on 800,900,1800 and 2100 Mhz.
the phone can only connect to 4g and only to band 20/800 Mhz,
no other cellular connection is possible.
bluetooth works,
wifi works 2,4 ghz/5Ghz.
i restored the phone with itunes in dfu and recovery...
i used other simcards...
the issue started 1 week ago.
the hast a light crack in the front glas, but this happend earlier,
the phone bends right under the volume down button.
maybe you can help
1 Comment
ach,habe ich es jetzt ins deutsche forum gestellt nach dem einloggen ?. okay
by
Add a comment
1 Answer
Most Helpful Answer
This leads me to believe there may be a crack in the antenna part of the housing.
As you can see there are about 4 spots on the housing where the antenna is part of the housing, top left and right, bottom left and right marked as a brighter color than the housing white or grey for example.
Replacing the housing may be worth a try if you can find good quality housing with pre assembled parts.
Here is a guide if you are willing to go ahead and DIY it, it's very time consuming:
iPhone 6s Rear Case Replacement
Score 3
3 Comments:
i swapt the chasis on an iphone 6 yeah, it took abot 2 1/2 hours for me.
but the upper part, isn#t even touched, everything is in place...
are you sure...
which antenna could be broken ?
by
could a batty failure result in this ?. battery health is at 80%...
by
No, I have not heard of reception issue being caused by a bad battery.
by
Add a comment
Add your answer
carljirigross will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 317
